  • alan bradley lights flashing
    Posted by Roger on April 16, 2019 at 8:31 pm
    storing without electrical hookup…
    shut off 12 and 24 cut off in side engine bay
    unplugged ribbon for gen watchdog
    shut off 12 and 24 cut off in electrical bay
    inverters shut off in coach panel
    all breakers turned off
    today did reverse and all comes to life but the alan bradley lights flash and the touch screens will not work including generater start.something im doing wrong? did try AB reboot.Coach is a 1998 liberty lady
    Bernie replied 7 years, 6 months ago 10 Members · 12 Replies
  • 12 Replies
  • Roger
    April 16, 2019 at 8:54 pm
    I have a 1999 Liberty Elegant Lady XLV (24 volt coach). I’ve done the same thing as you have for varying lengths of time (usually a few days to a week) without incident.
    I’m just guessing, but its possible the battery for the Allen-Bradley computer might have run out of juice. Any idea how old it might be? I believe the battery is important to the A-B system.
    Hopefully one of the more knowledge members will be checking in shortly. Don’t despair, we’re here to help you.
  • George
    April 16, 2019 at 9:34 pm
    Verify house voltage. Pic of A/B would help…does yours have a key on the left side?
    April 16, 2019 at 10:03 pm
    AB battery new 2018…last week all went well……
  • Jeff
    April 16, 2019 at 10:08 pm
    Yes,the reboot key is to the left….
  • granvil
    April 17, 2019 at 5:56 am
    House Batteries what is the voltage please
  • Sam
    April 17, 2019 at 8:11 pm
    Got to the coach today dash reading for 24 volt house was 27…..tried the technique we talked about with no results…..all lights flashing on AB and none of the touch pads will operate lights,gen start etc…..
    All batteries seem fine
    May 2, 2019 at 7:41 pm
    All fine now……had an Allen Bradley engineeer
    from Rockwell install the program…..she said it was her 2nd prevost in a month…….all works fine now…..it was caused by a memory battery failure…..
    Thanks go out to Bill and Troy at Liberty….
    May 2, 2019 at 8:49 pm
    Please tell us more about the solution.
    Did you have to take the coach to the Allen-Bradley/Rockwell factory in Milwaukee to have it done?
  • Roscoeapproved
    May 2, 2019 at 9:51 pm
    They came to my storage place….she was local in Phoenix from Rockwell….travel is 197 per hr…..work is 234 per hr….took a bit less than an hour.
    All came to life but generator would not start….turned on engine…..then it started …..It now starts without. engine on…….
    I believe there are back up power batteries but also seems to be a small battery to hold memory….she said it will now operate without that battery….
    ROGER
    PHOENIX
    BUS 361 ELG LADY
    Jeff and Lindsay
    91 Marathon XL
    May 3, 2019 at 6:23 am
    Wonder if Allen Bradley is hiring. Just saying…
  • Roger
    May 3, 2019 at 10:14 am
    Roger: Do you know what the AB tech did? Were there new parts involved? Now was the battery apparently eliminated? How did they do that? Those of us with AB system are curious. We’ve had our coach for almost five years and the AB system has performed flawlessly. That said, if something goes wrong with it I don’t know where to start … other than to call Jeff Rowe and Liberty.
    May 3, 2019 at 11:42 am
    DICK
    I think what happened to my coach is not very common…..the other prevost the tech worked on had significant water damage…
    No parts are needed….she just plugged in and downloaded….I thick the download includes a program to keep the memory stored without the battery.
    The SLC 500 is still being used all over the country so that is why they have tech support for the AB.
    If you ever have problems call them and based on your symptoms they will guide you and determine if liberty needs to be contacted..
    Today I’m moving the coach to. A covered storage as I think the excessive heat here may have contributed to my problem…
