Airflow for generator cooling
1998 Royale with powertech generator on driver side radiator on passenger side
Trying to see how air is drawn into hush box for cooling of generator.
Does the air draw through the hush box foam on the back wall of the hush box?
If so will the years of contamination of foam reduce the airflow for cooling efficiency?
The foam is very dirty and decomposed from the age of 21 years.
Suggestions for replacement.
I assume the original is adhesive attached. Amy suggestions for removal and attachment of new
