AIR SYSTEMS
Moire and more I am learning about issues with air systems. For several years the number of problems reported have been rising. Now with bitter cold affecting coaches I can say with almost 100% accuracy if your air system has not been maintained, and you are using your coach in the very cold conditions you are going to experience problems.
The culprit is moisture. Even the smallest amount getting past the dryer and wet tank can affect air system parts. That moisture is corrosive and it affects steel springs, the bore in the Norgren valves, and it will often contribute to a build up of sludge in the Norgrens and other valves. And if it is cold enough the moisture freezes and the systems do not work.
If the moisture does not come from the engine driven compressor side of the system, it can come from the aux compressor which has water traps downstream that need draining.
What makes moisture in the air system such an issue is that when problems occur diagnosis is almost impossible because the system does not act or function as intended and nothing seems to make sense. At that point the only way to determine why something is not working correctly is to verify the operation of every component one at a time. That gets expensive and very time consuming.
