  • Air Lines After Slide out Controller 2006 H3
    Posted by Jeff on April 25, 2020 at 10:40 pm
    Not sure where to check next. When I close the Prevost factory installed chassis auxiliary air valve leading to the slide out controller, I have air loss faster in the slide out air “circuit” than I do in the rest of the aux air system.
    Maybe I am trying too hard to achieve the unachievable. Right now my aux air compressor will cycle about every 3 to 3 1/2 hours. If I close off the slide outs, it would cycle about every 8-10 hours.
    On the slide out side, I have checked everything after the Prevost factory installed aux air valve going to the slide out controller and found only one very small leak on one external solenoid type fitting. It has a male pipe thread fitting and I tightened it and it no longer leaks.
    On an 2006 year model H3 chassis, can anyone tell me what slide out nylon tubing lines remain charged with aux air? I assume only the lines to the seals themselves.
    And, also the location of where the tubing connects to each actual slide seal as I would like to check those connections.
    My slide controller and seal pressure adjustment valve was replaced within the past few years as was the salon seal itself.
    Suggestions on what else to check would be appreciated. Also, if I am going overboard trying to achieve perfection, please let me know that, too. Thank you, Jeff
    Dick replied 6 years, 7 months ago 4 Members · 3 Replies
  • rafael
    April 26, 2020 at 5:34 pm
    We had a similar problem on our ’06 XLII. Jeff checked everything and in the end the air block/manifold (shown in your pic) had an internal leak found by Danny with his teeny tiny camera. Prevost then shipped two defective blocks. The second was wired wrong but Jeff was able to rewire it correctly. What a guy! Persistent!
    April 26, 2020 at 10:44 pm
    Thank you for the reply, Doug. I have studied the Prevost air diagram for the slide outs and plan to attempt to find the connection at the air seal to verify if it is tight. If that is not the case, could be a similar internal leak. My controller was replaced a few years ago by a previous owner as was the salon seal.
    How often does your aux compressor run now vs. with your old controller.
    April 27, 2020 at 5:32 pm
    Jeff: The new air block/manifold stopped the slide air leaks … until the rear seal blew a few months later. Then I had two new seals and a new manifold and no slide air leaks. But of course more leaks came up elsewhere over the next couple of years and I fixed those myself. Sold it six months ago leak free.
