  • Air leaks
    Posted by Peter on February 21, 2013 at 9:10 pm
    Out to shop this morning air gone out of aux air good day to work on air leaks 15 degrees and snowing found that regulator was leaking above engine doors, bellows leaking tightened the one under fan. Is there a way to fix regulator? I have a new check valve ,one air line off of aux comp leaking one under steer comp , fixed with new fittings.bellow with band that could be tightened stopped leaking good day have new regulator coming as spare.I have found that checking for air leaks when it’s cold is the best push in fittings really leak then when there cold
    Peter replied 13 years, 8 months ago 1 Member · 0 Replies
