  • Air leaks
    Posted by Peter on October 11, 2013 at 9:19 am
    Replaced both check valves on air tanks one in front one on back they looked like original ones had to use heat to get them out new Norgen between front tires and one on back drivers side frame had leak on aux air and brake air it was push in fitting on tag lever and park brake had push in fitting too both where leaking put comp fittings in now air holds great Both Norgens where leaking to Tag axle light on dash would not come on the tag switch sensor was bad unscrew shut power off took out put both wires back on works great now old one was in bad shape rust inside it is located at tag lever by parking brake
    Peter replied 13 years ago 1 Member · 0 Replies
