  • Air leak @ Parking Brake valve
    Posted by Mike on May 15, 2018 at 11:57 am
    Air leak was coming from ruptured pressure stat on side of tag axle valve. Replaced it and leak stopped. Now when I push in park brake valve the park light goes out but continuous air is leaking out in front tire compartment. When I pull the parking brake on it stops. Does anyone know what could be leaking in the tire compartment?
    Bill replied 8 years, 5 months ago 3 Members · 3 Replies
    May 15, 2018 at 1:42 pm
    Think the air leak is coming from either the spring Brake valve or Double shuttle valve. Has anyone ever dealt with either of these?
    May 15, 2018 at 5:28 pm
    I have replaced both the double check and the spring brake valve. There are also about 3 pressure switches in the same area and the connections for the dash air gages (1/8″ lines). I had leaks at the switch housing and the gage lines. I recommend you change the switches and be prepared to change the gage line fittings.
    There are a lot of lines in that area. I label lines and fittings (A, B, C ect) and once I get the valve out label the fittings and new valve to ensure the fittings go on the new valve correctly.
    It is not a hard job but you have to lay on your back in the bumper compartment to reach those items which are on the roof of the bay. My house batts and inverters are in that bay which makes space a premium. I have to move one of the inverters to the side (I have enough wire slack so I don’t have to disconnect anything) to fit in there. Yours is not likely that crowded.
  • Tom
    May 16, 2018 at 9:29 am
    Thanks Joe! For now, all I have is a spare tire in the compartment. Time to put on the old grease clothes and go at it! Appreciate your thoughts!!!
