  • Air leak
    Posted by Peter on October 2, 2014 at 12:54 am
    Today when driving from Billings MT to Spokane WA I saw aux air going up and down so when I stopped at truck stop I checked it out, it was the valve for the black tank that sends signal to gate valve to open , I went to steering bay found hose put ball valve in to shut it off , Thanks to Jeff Rowe he is sending new one to me and for his help, that could stop you dead in the water if it leaks and engine comp can not keep up, in my liberty there are lots of things with aux air, in my Royale I put ball valves in just in case of that reason, But have not had time when I am on road all year but Jon had put some in his coach , I will be doing same thing it could save you a lot of down time if you do it ahead of time, try finding small ball valves in some places , I carry some with me so it was no problem, I do not know why they don’t put the ball valves in when they build it, it can drain the aux air system fast , so if you guys have time put some ball valves in just in case something goes bad , you can shut off seat, air horns, step slide, tank valves , air doors inside and fix it when you can get the parts!!!!!!!!! Hope this helps somebody .
    I also have two ABS valves leaking will put new ones in this weekend!!!!!!
    Peter replied 12 years ago 1 Member · 0 Replies
