Air Horn
The air horns are not functioning. I suspect the solenoid is the problem. There are two wires leading to this solenoid and I don’t know if they lead back to the Liberty fuse panel (possible fuse 41A) or if it is protected on the Prevost side. Anyone with my vintage of coach who has dealt with this issue I would appreciate your input. Also as depicted by the attached photo the solenoid in question is the one on the right. It looks like a two way valve normally closed, 1/4 inch air service and output and supplied/actuated by 12v DC. What replacement for this solenoid is recommended. Thanks
PS I realize there is a toggle switch on the dash that must be on to the air horn setting in order to actuate this feature.
