  • Air governor problem
    Posted by Mike on October 18, 2022 at 9:25 am
    Good morning Everyone, I’m having an air
    governor issue. Can someone give me some
    advice? I replaced my air governor and dryer
    filter maintenance. The new governor did not
    cut out even at 150 psi. So I shut down the
    engine and adjusted the governor to cut out
    at 120 psi. The problem I’m having now is
    the governor will not cut in until it reaches
    80 psi. Do I have a bad governor? Or can I
    adjust the cut in? Thanks in advance!
    TRUE replied 3 years, 11 months ago 7 Members · 6 Replies
  • Jeff
    October 25, 2022 at 7:50 pm
    Guess no one knows the answer.
  • Chuck & Katrina
    October 25, 2022 at 8:02 pm
    I would just change to another replacement Gov. If that doesn’t work your prob looking at unloader in air compressor. Then that depends on your skills. also make sure your gasket is aligned correct between pr and compressor. Bob
    Leesburg, FL
    October 26, 2022 at 4:55 pm
    This is a good question for Prevost PASS:
    https://prevostcar.com/contact/pass-247365-assistance
    PASS offers 24/7 availability 365 days a year. Just call 1-800-463-7738.
    Everytime I’ve used it, I’ve been connected to a smart, knowledgeable tech. One even driving home from work.
  • Roscoeapproved
    November 21, 2022 at 7:31 pm
    Thanks Bob & Dick! I appreciate the comments.
    Ok I changed the governor Bob and as luck would have it I never got a chance to see if the governor was the problem. The norgren valve on passenger side between drive axle and trailing axle started leaking air. Prevost doesn’t have one and Norgren took my order but has no clue when they will have one. Had plans for a trip during the holidays but that has been busted. If you have suggestions please send them and have a Happy Thanksgiving!
    Jeff and Lindsay
    91 Marathon XL
    November 21, 2022 at 10:19 pm
    Which norgren do you need? I have some new ones on the shelf. I could overnight one if i have the one you need.
  • TRUE
    November 21, 2022 at 11:30 pm
    Mike & Debra:
    I don’t know what part# you need??? I have the following spares:
    If you need a Norgren 3port/2 way spool valve or parts??? I have:
    a) 2 new Norgren/Prevost# K910026, same as Norgren# K41EA00KS1KA2.
    *** I also have 2 used that were working when I took them off yrs ago***
    b) and 1 used Norgren 3port/2way body with spool, # K41EA00.
    c) and 1 new Norgren 3port/2way spool with o-rings, Norgren kit# 54237-59
    or
    if you need a Norgren 5port/3way spool valve??? I have:
    a) 1 used Norgren/Prevost# K910058, same as Norgren# K81EA00KACKAC
    b) and 2 new Norgren 5port/3way spools with o-rings, Norgren kit# 54237-56
    If you need any of this, email me @ donjetman@aol.com and we’ll work out the details.
