Air filter restriction indicator
I’m looking for information on perfect, reasonable, and replace when it comes to air filters……found a little device on Amazon that screws into a port on the fresh air inlet tube. It is basically a non-resettable vacuum gauge that records the max suction (in inches of water column) your system has seen. Or in other words, it indicates how restricted your filter is with particulate, etc.
The device is calibrated from 6 (no restriction) to 20 (RED – Replace your filter now)….does anyone have experience with this? Is 20 inches of water too restrictive? (Jon, I suspect you have some experience with these)
Tnjet
