Advice on replacing valve stems – (Alcoa wheels)
June replied 10 years, 10 months ago 11 Members · 17 Replies
Alan,
I want Pressure Pro. Why? Apart from the fact Tom sells them there is no other system on the planet that makes it easy to use multiple toads. I can tow the 50 Ford, the H2 Hummer or my Ram 2500, all of which are set up for towing. Switching from one to the other is easily done. The Pressure Pro system is set up for multiple toads.
Tom has assured me the sensors don’t leak. But the President told me I could keep my doctor also so I do have a degree of cynicism. When I replace my tires however, the time to bite the bullet will have arrived. If only Pressure Pro will offer an internal sensor I will do a happy dance because I can have my double seal and Pressure Pro. (Pressure Pro, are you listening???????)
Now with respect to Tom buying Nancy her 2 slide coach, I’m pretty sure we will have peace in the middle east before that happens.
I have Tom’s pressure pro system and I don’t worry about valve stem leaks. I can check my tire pressures as many times a day as I please (and I do). If a stem or tire starts to leak, I have ample time to address the problem. I do not have valve stem extensions and I was able to install the sensors using Tom’s patented, PVC tool. So far no problems. We always change out the valve stem if we break down a tire for any reason. Especially on aluminum rims. Haltec Series TV-550.
