  • Additional cooling fan for inverter’s
    Posted by Chuck & Katrina on August 18, 2022 at 8:58 pm
    My inverters are mounted high in the same bay as the generator and HVAC house unit and get quite hot. I am considering adding a squirrel cage fan with a temp switch to assist in keeping the inverters cooler. Should I use a 24 volt fan or a 120 volt fan? Both voltages are readily available at the inverters and available whether on shore, gen or battery.
    I guess the question is, what will draw the least amount of amps
    Chuck
    Leesburg, FL
    Art replied 4 years, 2 months ago 2 Members · 1 Reply
  • 1 Reply
    August 19, 2022 at 12:30 am
    Liberty installed a 115v fan that is on anytime the #1 inverter is on.
    This year I installed a 2nd fan, 12v that is controlled by an adjustable thermostat snap switch, 90*f to 120*f
