  • Accessory Air Filter and Belt Tensioner Regulator
    Posted by Michael on July 20, 2020 at 9:53 pm
    I did not see any prior discussion about this so thought I would start and see what people do. I read in the Maintenance manual for my XL that I should be changing the filter element and gasket of the accessory air filter every two years. I also see they recommend disassembling and cleaning the belt tensioner pressure regulating valve. I have not done either of these maintenance suggestions on my XL and am wondering if others are following this? Also, if so, I noticed no filters or gaskets are available from Prevost so wondering where you get those replaceable parts. I have not experienced any issues with my accessory air system, but want to avoid that in the future.
    Thanks for any insights!
    PS – Included pictures from the manual.
    Mike Harper
    2004 Marathon XLII
    Charles replied 6 years, 3 months ago 9 Members · 8 Replies
  • 8 Replies
  • George
    July 21, 2020 at 12:05 pm
    Every couple of yrs I remove, clean, change element, then reinstall that water trap. It never has been very contaminated. Here is my mx log entry from last Dec.
    Disassembled Bendix Type E aux air water trap. Reassembled w/new FF244 filter element. Prevost pt# is 640073
  • Jimmy
    July 21, 2020 at 4:21 pm
    Thanks Don.
    I called Prevost Parts and they said they do not have any filters or gaskets for that style anymore and recommend moving to a new design (part number 641338) which has replacement filters available (641340).
    Unless I can figure out another source for that type filter and gasket I might just have to do the change out of the entire canister.
    July 21, 2020 at 5:22 pm
    Where is the filter located. Have a 1998 Royale.
    This is a Prevost item I assume due to the part numbers being Prevost.
  • Harry
    July 21, 2020 at 7:07 pm
    On our bus it is located just inside the steer compartment door at the lower right.
    I use Fleetgaurd # FF244 and I make my own gasket out of sheet gasket material from NAPA.
    Here’s a PC thread I did in Jan of 2017: LINK
    July 22, 2020 at 8:46 am
    Thanks Don!
    Somehow I missed that thread when looking before posting. I am going to give that a try.
    Yes, inside the steering compartment on the right side is where mine is as well.
    July 22, 2020 at 12:29 pm
    Don,
    Any chance you can post a link to the filter? I see an oil filter with that number but not a string filter.
    July 28, 2020 at 4:54 pm
    Sorry it took me so long to reply. We took a little vacation from everything.
    I did a little searching and it appears Fleetgaurd may have discontinued their # FF244. My source in the past was simplyfilter.com for $13. You can send them an inquiry at inquiry@simplyfilter.com.
    I did see a Fleetguard FF244 replacement on amazon by “aftermarket filter experts”. No picture and it comes in a 3 pack at: amazon FF244 LINK
    Below are pics of my old filter. It can be washed, dried, and reused.
  • Charles
    July 28, 2020 at 9:29 pm
    Thanks Don!! Hope you had a great vacation. We head out Saturday for a couple months – can’t wait to get back on the road.
