ABS code 273
I was puttering around in the compartment below the driver’s seat checking for aux air leaks while the engine was running and saw the red ABS indicator light flashing. Interesting. Did not know I had such a light. There is a switch next to the light marked (Blinker, Normal, MPSI). It was on “Blinker”.
Came home and looked up the Meritor ABS codes and sure enough, the code 273 indicates “right rear drive wheel ABS sensor circuit failure”. It says to check sensor, circuit or connector.
I did have all air bags replaced recently. Maybe something got disturbed. What should I be looking for?
Thanks, Gerald
