6 way plug
Does onyone know if liberty installed a brake wire in their 6 way plugs? I went to install a brake controller for the trailer
I ordered. I took apart the 6 way plug in the rear and found a blue wire in the center of the plug. That is where a blue wire should be and coming from the brake controller. That wire is the one that is powered when you apply the brakes thus applying power to the trailer brakes. This wire does indeed powered when the brakes are applyed. My only concern is how do you adjust the amount of power to the trailer like you would on a brake controller. Rick
