  • ? #2
    Posted by Bob on April 26, 2012 at 9:02 pm
    the post the coil sits on shows a red top on it. The post is threaded. Should that be plugged. That part of my system is missing.?? When selonoid releases air excapes thru them? Bob
    Tom replied 14 years, 6 months ago 3 Members · 3 Replies
    April 27, 2012 at 5:32 am
    Bob,
    I assume you are talking about the solenoid valves on the manifold that operate the suspension system. The post on the valve itself has a red “cap”. When the solenoid coil is not energized thus closing the valve, the pressure from the solenoid valve to the norgren spool valve (3 or 5 port) is exhausted so the spool valve can return to its normal position.
  • Tom
    April 27, 2012 at 9:48 am
    Yes that red cap. Is it necessary to be there or just a dust proctector air can flow thru. Mine are all missing. I know this may be a dumb question. But I intend to understand this system totaly! My goal!. The stem is threaded internaly. Thanks Bob
    April 27, 2012 at 12:26 pm
    I don’t know the purpose of the cap. Prevost? Is it a bad thing for the cap to be off?
