Yes, but if you have ever stood behind your coach with the clutch engaged on high speed you would know the modest change in RPM is slight because even at idle the high speed on the clutch moves a scary amount of air.
Please note:
This action will also remove this member from your connections and send a report to the site admin.
Please allow a few minutes for this process to complete.
