  • Profit Tools Fuel Card
    Posted by Archived on September 10, 2016 at 8:54 am
    Two nights ago I stopped for fuel at a Loves in South Georgia. When I tried to use my fuel card I was asked the usual questions. The reader took my driver ID as usual then asked for the truck number but would only take 3 of the 4 numbers. I tried the first three, then the last three and the sale cancelled both times. Another pump was free and I had the same experience so I bought fuel the old fashioned way. This occurred after business hours so I could not call Profit Tools. I then got busy the following day and neglected to follow up. Has anything changed with our program? Did I miss a memo somewhere?
    Archived replied 9 years, 8 months ago 11 Members · 21 Replies
  • 21 Replies
  • Brady
    September 10, 2016 at 8:58 am
    I’ve had the pump reader only display three numbers when in fact I put in four. However, after I press “Enter”, I’ve had no problems getting fuel. I think the display sometimes cuts off the first digit.
  • June
    September 10, 2016 at 10:51 am
    Tolson, same thing happened to us…call Profit. Our # somehow got changed from 4 to 3 digits. One call got our old # back.
    September 10, 2016 at 1:49 pm
    This may be a universal problem and everyone should be alert because if you fuel on the weekend you cannot get help while standing at the pump.
    I fueled last Tuesday and it took my first four letter code, but it would only take three of my 4 digit “unit number”.
    A call to Profit revealed both my 4 digit ID and 4 digit unit number in the system were not the numbers I have been using since the beginning. Deb Nau, our contact at Profit gave me the numbers the system shows, and after I got the pump turned on edited them to go back to my original numbers.
    I refueled again Friday and everything is working as intended.
    I would suggest that if you are planning on refueling during a weekend, verify the user id number and the PIN (unit number) are correct. During the week if there is a problem you can do as I did and contact Deb and she can give you the numbers while you are at the pump, and if wrong correct them to what you want them to be.
    September 10, 2016 at 2:56 pm
    Used both (4) digits codes last week and all worked OK…. So not sure if isolated or it is change…… Refueled in MS, IL, and MO….
  • needtocamp
    September 10, 2016 at 4:56 pm
    As a follow up, over the last two months, I refueled at Love’s in KS, SD, ND, WY, & CO without any issues.
    However, there is no Profit Tools refueling service station in MT, so plan ahead. They take the fuel card at their truck stops, you simply don’t get any discount thru Profit Tools.
    September 10, 2016 at 5:50 pm
    MT and IN have a tax structure that prevents our use of the cards at stations in those two states.
    When Alicia was with Profit Tool she worked very hard to see if there was a way to get around it, but could not come up with a solution.
    September 10, 2016 at 6:20 pm
    Fueled the bus at Flying J in Peculiar, MO. Using Loves fuel card accepted, began furling. At $500 pump shut off displaying message “see cashier”.
    Cashier said she just started employment a week ago, had no idea. Any one have any ideas ?
    September 11, 2016 at 12:12 am
    fueled in Arkansas last week. System accepted 3 numbers for code and 4 for unit. Go figure!
    September 11, 2016 at 6:38 am
    It sounds like there are some glitches. I do know that Deb Nau cannot verify your two four digit access numbers because she does not have a way to compare what the system shows to what they should be.
    If you have any doubts, or have had a problem phone or email Deb and let her know what the 2 four digit numbers should be.
    Please contact Deb Nau with any questions at 603-659-3822 x 4528, or dnau@ProfitTools.net
    September 11, 2016 at 8:40 am
    Used mine Friday in SC and did not see these issues. I will say I have never had a problem like this show up while using my Pilot/Good Sam card.
    September 12, 2016 at 5:51 pm
    Used my card in Texas last week with no problems.
    Bill
    September 12, 2016 at 6:30 pm
    Al: You should have used the other fuel card for non Love’s locations. I was told the Love’s only works there and to use the other card for all other brands.
    September 12, 2016 at 7:26 pm
    No Sir Mark.
    The cashier knew the Coburg Queen doesn’t make much smoke, she figured fifty bucks was enough.
    Maybe the new Oklahoma fifth wheeler who’s got it now will drive it.
    Later
    bv
  • Kurt
    September 12, 2016 at 7:45 pm
    Bernie, yes! I heard all about that from BA
  • Alex
    Yep, bet you money the Queen driver was using the wrong card and was on the RV side having stimulating conversation with the RV crowd, fueling is a social event you know.:)
