  • Unknown Member
    October 9, 2022 at 2:59 pm
    thanks for the advice!
    will stick with 85w140.
    October 9, 2022 at 5:26 pm
    I use recycled fried chicken oil with an additive of KY Jelly and have never seen high temps on my third member, not to mention the power divider.
  • George
    October 10, 2022 at 11:38 am
    I forgot about adding KY jelly…great friction reducer I hear.
    October 11, 2022 at 3:34 pm
    Dick: With high ambient temps (90F+++), pulling about 70,000# gross, and traveling at 75mph, I have no problem reaching an indicated 250F in about an hour or two of driving. Temps will continue upward unless I make a pit stop or I can keep them at 250F by reducing speed by 5-7mph.
    I added the diff temp gauge to my coach because my 1990 came equipped with one and I realized how important it is under certain conditions.
    I change my synthetic diff fluid every 30,000 miles. I went to 50k once and when I pulled the drain plug, nothing came out. Had to stick my finger in to break up the clump of powdered iron blocking the drain.
    October 11, 2022 at 7:53 pm
    Is there a bung in the differential case for the diff temp probe?
    “Had to stick my finger in to break up the clump of powdered iron blocking the drain.” OH MY!!!! OH MY!!!
    October 12, 2022 at 1:14 pm
    There was a bung on mine. Had to put a ground wire on axle and stole a wire from something else (rear radar detector??) for gauge.
  • Jon
    October 12, 2022 at 1:32 pm
    Thanks Joe!
    October 12, 2022 at 6:12 pm
    oil: suggest what was original fluid at time of mfg. I changed one to syn= rear end noise. FWIW…my 98 came with diff temp gauge. Bob PS so many opinions all I can do is share experiences.
Page 2 of 2
