check my gallery and do no have a photo of my
engine Compartment on my phone. I won’t be back to Florida for about 7 days, if your configuration is like mine the line I refer to is a steel braided line that goes from the top of the compressor head to a manifold block that is located at the passenger side engine access which is the last compartment door on the passenger side. Where the line connects to on the compressor houses a small metal mesh filter that gets clogged and does not allow Freon to get the manifold causing all sorts of issues. I had no idea of this filter until I started having issues and a Prevost tech told me to check that location for the filter and luck have it that was the issue. There fix for it is simple just pop the filter off and reinstall he said they never put them back on. When I get back to my bus I will snap some photos for you.
