  • Bubble Wall
    Posted by Kirby on February 20, 2016 at 8:27 pm
    I’m wondering if anyone has experience with a “bubble wall” in their coach. In our new-to-us 1996 Marathon, there is a bubble wall. We thought at first that it was just a decorative etched glass panel between the shower and the bedroom, but have discovered that it is two glass panels with space between, filled with water. The water level is down about 6 inches, showing a visible water line. We asked the previous owner about it, and he said he never used it and he thought it was empty. It’s not empty but we would like to drain what is apparently 20-year-old water.
    In the paperwork that came with the coach, we found four pages of instructions on how to fill, how to empty, troubleshooting, and a schematic. We followed the directions and it fails to drain. Tried activating the pump via the switches labeled “bubble wall” and “high bubbles” but the air pump just vibrates.
    Any ideas?
    Kirby
    Tim replied 10 years, 7 months ago 13 Members · 16 Replies
  • 16 Replies
  • Dan
    February 20, 2016 at 8:56 pm
    Sounds to me like a clog. Especially since the drain and air pump seem to be clogged. If it were me I would take very, VERY, low air pressure to the drain and see if it helps unclog any debris/settlement that could be there.
  • Kirby
    February 20, 2016 at 10:41 pm
    Apparently not the kind of coach you’d want to let freeze up!
    Can you find the plumbing/hoses for the drain? There must be hoses, plumbing below “the wall
    February 20, 2016 at 10:55 pm
    SouthernLand, I will try some air… might even try a toilet plunger on the outlet in the shower to see if that will loosen something up.
    Dick, I have a firm policy against being in freezing weather, LOL.
  • Billy
    February 20, 2016 at 11:34 pm
    The record low temps for Hollywood, Florida for Dec, Jan, Feb, and March are 32*F or lower.
  • Jimmy
    February 20, 2016 at 11:40 pm
    I have never heard of that type of wall and wonder what the purpose is/was.
    Hope that you find the fix.
    MM.
    February 21, 2016 at 12:57 am
    Here MM,
    It’s an accent feature. Seen them in a few coaches.
    February 21, 2016 at 9:57 am
    In 6 years of reading and posting about Marathon’s …this is a new one.
    Before you do anything at all, take a break and give Leon a call in Coberg, Monday.
    With your coach number he’ll have access to the build sheets on your coach.
    If anyone on the planet knows about your bubble wall it’s, Leon
  • Hector
    February 21, 2016 at 11:36 am
    And I would suggest if it’s not an emergency, you email Leon first ( tsd@marathoncoach.com ) so he has some time to pull the build specs. He’s a busy guy but always returns his emails.
  • Walter
    February 22, 2016 at 11:51 am
    Good tips, everyone… thanks!
    February 22, 2016 at 4:59 pm
    Kirby:
    We have #409! One of the prior owners had Marathon remove the Bubble Wall but we still
    have the 4 pages of instructions that you probably have…we’re at RiverBend this Winter…send
    your email so we can compare notes re learning curve!!
  • joel
    February 23, 2016 at 10:02 pm
    Rick… learning curve is right. Spent the last 23 years in a GM4104. On Thursday we’re going for a short-ish trip to a Southeast Bus Nuts rally in Wimauma, FL. Never been there, but we have lots of friends in that group. Lots of different buses — MCI, Eagle, GM — but they do allow Prevosts to join them. Not sure how to send e-mail address, does this board have a way to PM?
  • Rudy
    February 23, 2016 at 10:23 pm
    hello Kirby & Linda,
    if a person has their email open, you can click on their ID (JohnKirby) that will,open an email for you to directly send that person an email.
    you open your email to this option in your profile, yours is currently not open to email.
    February 23, 2016 at 10:38 pm
    Thanks Paul.
    February 24, 2016 at 5:24 am
    We decided when the site was created to not have a PM feature. One of our objectives was to provide the most security we could for our members and their privacy and if we had a PM feature that could be compromised.
    If someone wishes to communicate with a member whose email is not publicly accessible you may send Tom or I an email which we will forward to that member. We will not reveal anyone’s email address or any other information from their registration or profile.
    April 10, 2016 at 4:09 pm
    I have coach #361 and have the wall and i cant get mine working… any luck getting yours going ?
