Roger, you have introduced what might be the issue related to your compressor cycling. Whatever changes you made when you modified the Liberty / Prevost system may be you problem. If you are bleeding off compressor head pressure air (aux compressor) are you also bleeding off accessory air from the accessory tank????????
Every 2 or so years it will take 10 minutes to remove dryer, change cartridge reinstall. Got tired of the old dryer’s little issues.
Jon, this Prevost Liberty has the original style factory installed dryer. It uses wet tank air to purge by design. No changes there. And your statement regarding what is seen on the acc gauge is correct, but by Prevost design.
Had to extend 1/2 line 4 inches from compressor, Is that OK the way I extended line or should I have done something different with out replacing line?
